camshaft pulleys
macawlover70
camshaft pulleys
Post by macawlover70 »
how do I tell which pulley is for the exhaust and which one is for intake?
mdrburchette
Re: camshaft pulleys
Post by mdrburchette »
There is an "A" stamped on the intake pulley and and "S" stamped on the exhaust pulley.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
johndemar
Your car is a: 1976 Fiat 124 Spider
Post by johndemar »
mdrburchette wrote:There is an "A" stamped on the intake pulley and and "S" stamped on the exhaust pulley.
And the exhaust has the lip on the front of the pulley, the intake on the rear.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
mdrburchette
johndemar wrote: And the exhaust has the lip on the front of the pulley, the intake on the rear.
That's true of most, but some later model pulleys don't have a lip at all. Of course, I don't know what years those are.
macawlover70
thanks guys. Had them on backwards, new head runs great now.
beachboy
Post by beachboy »
Denise, I had a 2.0 installed and I don't see the A or the S stamped on the cam pulleys. Where are they stamped? I have a 7 and a 9 stamped on the front of mine. One pulley has two alignment holes in parallel with each other, the other pulley has only one. Does anyone know how to differentiate the two?
ventura ace
Post by ventura ace »
The easiest way to tell is to look at the dowel hole that keys the pulley to the camshaft , and look at the alignment marks. When standing in front of the engine, facing the pulleys, if the camshaft dowel holes are straight up (12 o'clock position), the the alignment marks for each pulley should point toward the center of the engine. This rule should apply regardless of whether or not the pulleys are stamped and whether or not there are belt guides at the front or back of the pulleys.
Alvon
beachboy
Post by beachboy »
Thanks Alvon,
I have looked at mine and the alignment marks are to the outside of the dowel. This means I have to reverse them. The alignment marks are just a few degrees off from the dowel marks, so one has to look closely, but you can tell which is inside from outside.
FiatMac
Post by FiatMac »
With respect to the question of when the cam wheel lips (flanges) were eliminated, based on looking at engines I have, I believe that occurred during or after the 80 model year. At the same time the lip on the aux. pulley was moved to the rear to keep the belt from running off the back – the front pulley on the crank keeps the belt from running forward. My '76 and '78 engines have flanges on the front of the exhaust and aux pulleys and on the rear of the intake pulley. I have a '79 with the same set-up. I have an '80 with the same except for a flangeless exhaust pulley. My '82 has flangeless on both intake and exhaust with a flange on the back of the aux pulley.
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
83 parts car
