I have a '78 124 spider and want to add a oil pressure gauge that I got with the sending unit from a '77. Currently I have a wet gauge that a PO added to the car. I need to know if the connection from the '77 will screw in where the big nut appears or if I have to come up with something else. Attached it the current set up, it looks like it is a 1/8" NPTM fitting with the compression fitting on the outlet. (I expect it to be metric) I wonder if that is a reducer that the fitting is screwed into and if the standard sending unit should thread into that hole that the reducer is in.
Please share if you can I really want to make the change.
Thanks in advance
Oil sending unit
- Your car is a: 1975 Spider
Re: Oil sending unit
the factory oil pressure sending unit will screw directly into the oil filter housing without any adapters
son has 78 spider
son has 78 spider
So from what I am understanding that nut closest to the block is an adapter and should come out without any real issue, would you agree with that?
Thanks.
Thanks.
