compression test without manifolds
cski
Post by cski »
Would a compression test, done without the manifolds attached, be meaningful?
TulsaSpider
Re: compression test without manifolds
Post by TulsaSpider »
I don't see why that would effect anything. You are testing the sealing capacity of the piston rings and the valves.
