EFI fuel pump from other car?
boxdogracing
Post by boxdogracing »
I have an 83 spider and after troubleshooting EFI, bad pump no pressure. So my question is does anyone know of other cars with a pump that will work, it seems to me that any inline EFI pump should work. I don't care if I have to fab brackets to mount it. A stock Bosch pump is $338.00 from IAP outch!! and it would take at least two days to get. There is a junk yard near me that will sell me any in line pump for $25, but it would save time if I knew what cars to look for. Any ideas?
mdrburchette
Re: EFI fuel pump from other car?
Post by mdrburchette »
You should be able to cross reference a EFI pump from a Ford F150 with a 302 EFI....early 80's model probably?
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
Foster48x
Post by Foster48x »
This is the one from Autozone that Denise is referring to, or one like it.
Airtex Master.
PN# E2182
$89.99
Rick
boxdogracing
O.K. made it to the junk yard turns out late 80's jaguar xj6's have a pump that is a perfect fit even the electrical connections are a perfect match the only visual difference is a sticker that says Lucas. Also late 80's BMW 3 series use a very similar pump still Bosch but ring terminals for power instead of spade connectors. I picked up one of each. I will post whether or not they work for me. I also found new replacement pumps for the BMW on Ebay for $80 shipped, so that could be a low cost alternative to the factory pump.
boxdogracing
Running good again, sorry for the wait (driving for a change) So first I tried the Lucas pump DOA (go figure Lucas). then the Bosch all I had to do is change the electrical connections to ring terminals. Runs great I don't know the specs for either pump, but the BMW had a six cylinder motor I assume was larger. The BMW is obviously a more common car so replacement pumps are readily available, also if there is a difference between the pumps my guess would be the BMW pump would flow more. Since this is pressure regulated return line system I don't think it would matter. If the pump is more capable it will only help in my case as I'am currently building a turbo setup, and think the stock (and probably this one) may become maxed out at some point. Anyway If anyone else is a little daring or would like to save some $$ the BMW pump worked for me. 8)
