Driving through pretty French countryside to get a coffee at a pavement café I arrive at a roundabout and the engine cuts! It starts fine and I continue to café. Arrive at café and as I pull up engine cuts again. As I reverse into parking space various drinkers make furious signs that they are being choked by fumes.
Driving home I struggle to keep the engine running whenever I come anywhere close to stopping and whenever I lift of the throttle there is much popping and banging from the exhaust.
I'm afraid I have driven modern diesels for so long now I seem to have forgotten my basic petrol engine rules. Anyone got any views before I head for the repair shop?
Engine cuts out at low revs etc.
Re: Engine cuts out at low revs etc.
Sorry to be so thick but how do you tell if an automatic choke has closed?
I had a problem with the vaccuum hose on my braking system. Whenever I stepped on the brakes the vaccuum leak robbed the neccessary vaccuum from the carb and I stalled out. It would belch out smoke until all the unburned fuel in the pistons was evacuated. Car would idle and run fine until I stepped on brakes.
Don't know if this helps.
yeah, just take it to the shop. (Then, when they fix it, ask them to open the hood and point at and explain exactly what they did. next time, you'll be a little bit wiser and a little less scared to attack it on your own.) I'm sorry if I erroneously assume that you don't know how to work on your car, it's just the impression I got. no offense intended.
Thanks Danno.
Did I take offense? only a little. Did I find your reply patronising? Deeply. Was it helpful? Not really.
I enjoy owning and using my Spider. I have a local garage who like classic cars and look after it for me.
If it has a mechanical problem I like to understand what it is before they fix it. Hence my post.
My 82 FI automatic does the same thing. When I come to a stop light the revs go down and it will eventually stall. I can drive all day and its fine. I did check the brake booster and plugged the vacume advance.
Any good ideas???
Rob
Moraisr@usa.net
Any good ideas???
Rob
Moraisr@usa.net
