I'm not offering help... I need it.
Can anyone give me any tips on replacing the rear crankcase seal on my 79? I read a thread somewhere where advice was offered but you think I can find it when I need it? I've managed to get the old one off but putting the new one in is a challenge.
Some steps 1, 2, 3 etc that improve upon my manual's advise would be greatly appreciated:
REPLACING A CRANK CASE SEAL:
step 1: remove old seal
step 2: install new seal
Help with rear crankcase seal
- Your car is a: 1979 Spider
Re: Help with rear crankcase seal
Alright I sorted myself out. after destroying the rubber seal I bought one with a metal rim. that allowed me to tappety tap tap tap it Happy Gilmore style.
there are two different inner diameters, and your 79 uses the larger one. There is only 4mm difference, so it's hard to see unless you look closely. If you had a new small seal, you wouldn't get it in.
We learned that the hard way. We had too big of one and it poured oil.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
