Just finished a tranny drain and refill. Followed SOP with 2 quarts of Napa GL1 and a drill pump I've had for years. Now its time for the the rear end. Just need to know how much fluid and which hole to fill.
Thanks for your help.
Joe
Stuff the punkin
- Your car is a: 1982 Pininfarina
Re: Stuff the punkin
Joe,joephish wrote:Just finished a tranny drain and refill. Followed SOP with 2 quarts of Napa GL1 and a drill pump I've had for years. Now its time for the the rear end. Just need to know how much fluid and which hole to fill.
Joe
You will have two plugs on the differential. The lower plug (driver's side) is the one you remove to drain it. When you remove it, make sure to inspect it for metal shavings because the end of the nut is magnetized. Clean it off and put it back in. Then look up a little higher towards the front of the differential and there is another nut that you remove to fill it. Both nuts are 17 MM.
Usually, a quart and a 1/4 to a quart and a half should fill it. Just keep filling until fluid comes out of the hole that you are filling. And make sure to use GL5, which is specifically used for rear-ends to prevent breakdown and foaming.
Hope that helps.
Thanks for the information. Hope your move to Texas goes well.
Joe
Joe
It's always a good idea to make sure that you can get the 'fill' plug loose before removing the drain plug. You'd hate to drain all the oil out, then not have a way to fill it back up.
Alvon
Alvon
- wachuko
- Contact:
+9999999999ventura ace wrote:It's always a good idea to make sure that you can get the 'fill' plug loose before removing the drain plug. You'd hate to drain all the oil out, then not have a way to fill it back up.
Alvon
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- SLOSpider
how about drilling a new hole
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
- SLOSpider
You mean you cant fill it thru the axle with car jacked on its side?ventura ace wrote:It's always a good idea to make sure that you can get the 'fill' plug loose before removing the drain plug. You'd hate to drain all the oil out, then not have a way to fill it back up.
Alvon
1975 124 Spider
All went well. It took about 40 minutes total and I never had to lift the car. The old fluid was a bit dirty but had no surprises in it. Now it is on to the exhaust system. Cat or no cat, that is the question.
Thanks again.
Joe.
Thanks again.
Joe.
