Odd Vaccum reading
- Your car is a: 1980 Fiat Spider 2000 Fuel injected
Odd Vaccum reading
Hello i have a 1980 Fiat Spider 2L turbo. I decided to check the engines vaccum i had a odd reading so maybe someone can point me in the right direction. While the car is idling i get 17HG engine speed @ 900rpm, the needle however flickers 1/2 HG and as well the needle goes from up and down 1HG. While giving it a quick rev it pins 0 and then shoots to 23 then sits at 17HG flickering and going up and down 1HG again. I have tested the engine for vaccum leaks with no result, the only place i found a leak was the intercooler pipes which i fixed. The timing is set at 10 degrees @900 RPM, Replaced the Spark plugs with Magnetti Marellies heat range 7, Also Compression tested cylinders all came out about 120psi and did a leak down test which came back ok. Any ideas???
- Your car is a: 1975 Spider
Re: Odd Vaccum reading
i would recomend a compression test.most likely you have a valve issue
son has 78 spider
son has 78 spider
Beek-The car was compression tested and had a leak down test.
,Also Compression tested cylinders all came out about 120psi and did a leak down test which came back ok. Any ideas???
