oil dipstick gasket
tonysfiat
oil dipstick gasket
Post by tonysfiat »
I am about to start the removal process of the intake manifold on my 79 automatic spider, any ideas where I can get an oil dipstick gasket and a bracket to support the oil dip stick once the new manifold is installed.
manoa matt
OIL DIPSTICK GASKET
Post by manoa matt »
HEY TONY,
THEY HAVE THE GASKETS AT VICK AUTOSPORTS http://www.vickauto.com
CHECK OUT "TRYING TO STOP OIL LEAKS" IN THE GENERAL MANTINENCE COLUMN. THERE ARE SEVERAL DIFFERENT DIPSTICK DESIGNS
MATT
tonysfiat
Post by tonysfiat »
Matt
thanks
just my luck the 79
version sku#54-3606 has been discontinued.
Vicks recommends
piece rubber hose, and silicone.
I asked about other models you had listed they claim they would not work on the 79.
manoa matt
oil seals
Waight till So Cal Mark rings in He knows more about this than anyone, or since all those dipstick oil seals ares so cheep, order one of each and see if anything might fit with slight modification, and send everything else back.
matt
mbouse
Post by mbouse »
tony,
Check your email. I have your bracket covered, but you need to respond to the request.
racydave
Post by racydave »
Back in the 80s some GM engines were sealed with high temp silicone. Get some carb cleaner and clean mating surfaces, then apply silicone to stick tube, slide it in ,secure and give some time to cure. It will work!!!
only if the tube is secured so it can't move at all, and be careful that the sealer doesn't run down into the pan
tonysfiat
Post by tonysfiat »
thanks
mark and dave
thats what I will do, and be extremely careful
mbouse
Post by mbouse »
For some reason, the email bounced back. Look for it again, from my work address.
I hope you get it soon. If not ... holler and I will try a third time.
tonysfiat
Post by tonysfiat »
Mike
I did receive it, when I do not know.
Thanks for the help.
I responded to your request please look for it
I start tomorrow morning first thing with the removal process.
Will keep you posted with photos and commentary
mbouse
Post by mbouse »
TWO LITRE dipstick gasket
Fiat Part Number 82324106
I found one for my greedy self. Unfortunately, my source did not have any others to spare.
Fortunately, we all have the factory part number now.
