Hi All,
I have done this a few times before, but thought I get your input. Can you guys confirm this
Thread:
Left Hand hub has a RH thread
Right Hand hub has a LH thread.
This is what the book says, but looks odd. When I turn the wheel. The nut looks to undo.
Torque:
Preload to 15ftlbs
release and torque to 5ftlbs
Back off 30 deg (1/2 a flat)
This leaves the nut only finger tight. When the tabs are knocked in, I can lightly jiggle the nut.
Is this what you guys do?
Stub Axle Nuts - Thread and Torque
- ITA124
Paul
Fiat 124 Spider (Big Red Car. So my son tells me)
Toyota Corolla AE86 (Fiat as a daily driver? Not)
Fiat 128 Rally (Why did I sell this car?)
Fiat 124 AC (An iron ore waffle shaped like a 124. Donated to Sims)
Fiat 128 SL (First fiat)
Re: Stub Axle Nuts - Thread and Torque
It's opposite of what you would think so that is correct. They're not going anywhere once you bend the tab in. I can't find torque specifications in my book so maybe someone else will chime in.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
- kmead
This is what one does, there are a few things left out:ITA124 wrote:Torque:
Preload to 15ftlbs
Rotate the hub in both directions 4-5 rotations in each direction to seat the bearings while it is at the heavier torque.
Another thing left out is checking the runout which shouldn't exceed .005" which can only be seen with a dial indicator. If it does exceed that amount they suggest redoing the entire process.
It is a bit fussy, I confess I have tended to run my car a bit tight with no ill effects (so far). Be sure and use new nuts each time.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
1985 Bertone X1/9
