Adjustable panhard bar for lowered cars
manoa matt
Post by manoa matt »
Big brake kit is in, rims are almost restored, poly bushings on the way, plans to remove the bumper. After all that, the car will be lowered via cutting springs.
Question is: How big of a factor is the stock non adjustable panhard bar when lowering? I'd like the rear wheels to be inline with the front wheels, and not shifted to one side even if its only 1/4". Has anyone came up with an adjustable pan hard bar? I'm pretty sure I can fabricate one from a stock bar, but would like to build upon those that have gone before.
In theory when you go over a big bump and the rear suspension goes through the full travel the axle has to move to one side or the other due to the panhard bar.
launieg
Re: Adjustable panhard bar for lowered cars
Post by launieg »
I was surprised the first time I looked at the panhard rod. I had expected a Watt's linkage, and I can see that the car obviously moves laterally in one direction when lowered (either through cutting springs or while bouncing). I had expected a more sophisticated method (not that I'm complaining). I've seen fabricated ones with a Watts' linkage. Doesn't look too hard to do and should address all possible suspension positions, do you think :?:
Not a Spider, this example:
Launie
maytag
Post by maytag »
Lauine:
that's a nice-lookin' rear ya got there! :oops:
Seriously, that looks pretty hard-core.
Matt: what's the reasoning behind what you're trying to do? Are you building a track car? Or do you suffer from a little bit of OCD? :wink:
I set up a Watts linkage very similar to that on my race car, and it's really pretty easy. You could easily make an adjustable panhard rod, but any rear with that design will move from side to side as the suspension goes through its' travel
launieg
Post by launieg »
Lauine:
My wife has said the same thing, but I know she is biased :oops:
Seriously, I hope nobody thinks that is my car. I just found that example on the internet at a time when I was considering making one for another car. I though it was interesting because it was not a stock one (as far as I can see), but homemade.
Launie
manoa matt
Launie, A little from column A, and a little from column B. No seriously, its something I've wondered about for a while. I tend not to undertake projects unless I can cover all the angles, or until I have all the parts. Do it once and do it right. Thats why I have so many upgrade parts that I haven't installed yet.
I've been told by a member of another Fiat forum that lowering the car 1 inch results in the diff moving 0.015" from its original position. So by that logic, a 2 inch drop would be 0.03" = 1/32" I find these numbers hard to believe since the rod is not made to "exacting specifications" also worn/old bushings would induce more variance than 1/32".
I doubt that even 1/32" would be enough to cause feathering or scrubbing of the rear tires. However someone else also warned that lowering it too much will change the driveshaft pinion angle, corrected with adjustable short trailing arms.
Now you guys are probably wondering, "how low are you going"? As little as possible to get the look I want. I'll be droping in a 2L engine which is heavier with ancilleries than the 1.8L, but I'll be loosing the bumpers, so the lowering of the car will be one of the last modifications on my long list of projects. I think the biggest issue lowering the car will not be the diff location, but a big 2.5" straight exhaust pipe to scrape all the speed bumps. Again, refer to paragraph #1 undertaking projects......so I guess I fall into column B.
launieg
Post by launieg »
Mark, how did you attach it to the dif? Please post a photo, if you ever get the chance.
Matt, I will looking forward to this project of yours. I have my own dreams, and I like to learn from those who actually do stuff!
Launie
I doubt I have any pics of that Watts linkage anymore, but I welded a large stud into the differential cover for the pivot.
baltobernie
Post by baltobernie »
Since we're on the subject ...
Have any of you ever investigated the possibility of a non-Fiat IRS? Something plentiful, so that the parts could come from salvage. Maybe early BMW?
Miata rear axle assy :D
narfire
Post by narfire »
Although my memory suffers at times, I seem to remember a post here last year where someone had tried putting the rear end from a subaru onto the fiat. There was comment about the shock supports being scabbed on and likely not strong enough.
baltobernie
So Cal Mark wrote:Miata rear axle assy :D
(slapping forehead :roll: ) Of course! Anybody done this?
manoa matt
Mark, would the stamped sheet metal cover of the diff be strong enough to handle those forces without distorting the cover resulting in a massive gear oil leak? I've recently heard of someone boxing in the drop tower for the panhard bar to stiffen it up.
Please guys, NO FIATAS!!! I remember a similar thread where a newbie bought a car and had a post that said something like "does your fiat have an IRS?" The new owner bought a car that had been converted to IRS, but where the diff came from escapes me at the moment.
Snoopy
Your car is a: 1980 CS0 2000 f.i. US [Build 1979]
Post by Snoopy »
Look here: http://fiatspider.de/vb/showthread.php?t=3642
Thats whats build a spiderdriver...
CS0 2000 f.i. 79, Abarth 500C 595 2013, Ford C-MAX 1.0 Ecoboost 2015
MNspiderman
Post by MNspiderman »
Thats a great site if you speak german :D . I might be german but i cant speak it :(
