Need help with distributor.
my 81 fiat spider's distributor is sucking oil up through the shaft and spitting it into the cap. Does anyone know how to rebuild a distributor or fix the seals that are inside the shaft?
Re: Need help with distributor.
remove the distributor, drive out the pin holding the gear on, remove the seal. Assemble in reverse order. If the pin has never been removed, you probably won't be able to get it out very easily
- Europa
- Your car is a: 1983 Pininfarina Spidereuropa
International Auto Parts has a quick video on how to replace the distributor seal. Here's a link to the videos page.
http://www.international-auto.com/videos.cfm
1983 Spidereuropa
Verde Scuro
Verde Scuro
