What would you do with this engine?
perthling
Re: What would you do with this engine?
Post by perthling »
Shirley you can't be serious?
(PS for some reason 'Airplane' was known as 'Flying High' down here in Oz).
_______________________
Perthling
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
http://www.fiatlancia.org.au
manoa matt
Post by manoa matt »
I am serious, and stop calling me Shirley! Looks like I picked the wrong week to stop sniffing glue.
I agree with others, rebuild it to stock, drive it for a year, then plan out your performace mods systematically.
knightdalejb
Post by knightdalejb »
i found a step by step by mbouse using the ATF that mark suggested... i'm on step 1. kinda. i couldn't get that 4th plug closest to the windshield and walked away before i got too frustrated. everything is in the way and i can't get my socket wrench where i can get to it. any tips on this one? just be more patient?
mdrburchette
Post by mdrburchette »
Using a swivel and an extension on the socket makes it a lot easier. Remember the plugs are at an angle and when you reinstall them, make sure you use a little anti-seize, start them by hand, then use the socket to tighten them.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
Snoopy
Your car is a: 1980 CS0 2000 f.i. US [Build 1979]
Post by Snoopy »
the right wrench and you can remove the lock...
CS0 2000 f.i. 79, Abarth 500C 595 2013, Ford C-MAX 1.0 Ecoboost 2015
knightdalejb
ah.. guess i need to get a swivel. i have a feeling my tiny toolchest will be growing a lot with this car ;)
spiderrey
Post by spiderrey »
Drive the car stock for one year? Never heard that one before, whats that about?
I only suggested getting it running properly and assess the condition before making any mods. If it takes a year to do that I guess there won't be any rush
JDOliver
Post by JDOliver »
The only special tools I have ever bought in the last 9 years for the Fiat is a big ol bar and socket for the crankshaft pulley. The 4th one is a little tricky.
knightdalejb
progress...
I changed the oil and filter, new spark plugs (the old ones had a lot of black on them - too rich mix I think) and after dripping in some ATF for a few days, turned the crank pully nut and it moved with no resistance. Also I had drained the gas tank and glad to see it looks good on the inside, no brown chunks. went to crank and the key just spun around in the ignition switch... so I guess I need to order a new one, not sure what the PO did. as soon as I get that squared away I can try to crank it.
mdrburchette
You may have luck finding a used one if you post it in the parts wanted section. Plenty of us have parts cars.
knightdalejb
well i'm going to be adventurous and follow this http://www.mirafiori.com/~kdickson/switch/index.html to see if I can get it working, but I've perused the used parts part of the forum :)
