Radiator and Fans
bwilson27
Re: Radiator and Fans
Post by bwilson27 »
mdrburchette wrote:Do you have the external thermostat? Maybe your thermostat is in the housing.
Me? I don't have an external thermostat.
mdrburchette
Post by mdrburchette »
Then yours won't have the tee fitting since the right side routed the water from the external thermostat. Fiat went back and forth on what kind of thermostat they preferred. The most preferred one seemed to be the external setup and there are arguments for and against both systems. I have a car with each and couldn't tell you the pros or cons of either since they both work fine.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
bwilson27
Post by bwilson27 »
Oh, thanks for that. :wink:
I'd think a setup like mine would be preferred, since there are fewer hoses and it just looks 'cleaner'.
spiderrey
Post by spiderrey »
Your thermostat is in the front top of your head. at the back of your hose fitting. I prefer this set up so I did mine this way. Less is more under the hood
