Hey all!
I've searched and found some 'older' threads about this topic; but nothing resolved, or recent, or in MY AREA....
ROOK1: THIS IS FOR YOU, DOOD!
Where do y'all get replacement shims for your valve adjustments?
I have found a couple of on-line sources (mostly for kits) and right tnow that's not horrible, 'cuz I ain't driving the fiat in the snow anyway..... but in warmer weather, when I want to maike it a one-day project instead of one-week.... where do y'all head?
Tell me that Steve Harris Imports is not the only source? (or maybe they don't have 'em either? I know they always suck on Maserati parts)
Valve adjust - source for shims?
- maytag
Re: Valve adjust - source for shims?
The whole shim kit can be pricey but it saves on time and is very convenient. I got my kit from IAP. They also sell them individually: http://www.international-auto.com/
Do you have the proper valve adjusting tool? IAP may have one of those also.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
If you have a shim in your hand,try going to a volvo dealership if your in a bind. The older Volvo's use the same size (dia) shims, just check with a mic. before using, I found some different from stated thickness. I have used IAP for a source as well.
