adha to adfa switch
adha to adfa switch
just jumping in for help, 78 spider fiat 1800 with a 28/32 adha weber i want to switch it out to a 32adfa how tough is this to do my adfa has large round spring and cable atachment need to switch it to whats on my adha ball and socket to hook to my linkage
- ga.spyder
Re: adha to adfa switch
First off....I am not a carb expert,as you probably know from the post about my ADFA.I can safely say that the swap is a straight bolt in.A lot of guys switch your carb for the ADFA for a perf boost.That is usually done wiyh the single plane manifold,also.I know the rebuild kits are the same for both carbs.Wish I could be more help.I have a spare ADFA sitting on my bench that I have dis and re-assembled a couple times.I am learning.
Craig
Craig
Craig Nelson
Fling It Around Turns !
some of the hoses dont match up how about the jetting do you know if the larger jets go to the secondaries
- ga.spyder
I'm sorry.I dont have a clue.Someone here will pipe in with that info.Did you try a search on the topic?I know I have seen posts re. that swap,but I never paid much attention because I had a F.I. car.
Craig
Craig
Craig Nelson
