Can anyone advise where the vacuum advance is located on a fuel injected spider 2000? A picture would be great if possible.
Many thanks
Where is the vacuum advance on a fuel injected spider?
Re: Where is the vacuum advance on a fuel injected spider?
It's the little can on the dist. with a vacuum hose going to it.
Trey
Here you have it. is the gold vacuum actuator in the distributor base. The hose came from the injection plenum, just under the accelerator spring. The difference once instaled is awesome.
Just a question. Were these originally on the FI models or is it something folks have added?
they were standard on all 2L engines, FI or carbed
Thank you, good information.So Cal Mark wrote:they were standard on all 2L engines, FI or carbed
Tim
