Battery Charge Indicator Light
Foster48x
Post by Foster48x »
Does anyone know what might keep the Battery Charge Indicator Light (the small one on the speedo) on while the ignition is off on a 1980 FI. The light goes out after the car starts but whatever it is its causing the battery to drain while the ignition is off.
I did a recharge on the battery and it tested at 12.84v. The car doesnt have any problems starting. Not sure if it makes a difference but the center and radio consoles are out of the car with the heater blower cables unhooked.
Any ideas?
mdrburchette
Re: Battery Charge Indicator Light
Post by mdrburchette »
That's weird. What year car do you have? On the early model cars, the exciter wire went to a battery charge relay. I guess you could check to see if there is a reading with the voltmeter at the wire coming from the alternator to the relay and from the relay to the light and come up with what is causing it.
If it's a later model with the internal regulator, you can check the exciter wire at the alternator.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
rlux4
Post by rlux4 »
That's what I was thinking Denise. My guess is battery voltage is going through a closed contact in the alternator that should be open when the key is off. If that's the case, the light is reacting to partial battery voltage, instead of alternator output.
Ron
Ron Luxmore
rlux2n2@gmail.com
baltobernie
Post by baltobernie »
What about a faulty ignition switch? Pull the smallest wire from the alternator (the excitor wire) and see if the light goes out.
Any other circuits drawing power with the key Off? Can you see 12V at the coil, etc.
mbouse
Post by mbouse »
we're talking an '80 Spider here, so i don't think it is a relay issue. any chance the exciter wire is catching a short somewhere? i'm suspecting a failing regulator. like Bernie says... pull the exciter wire from the alternator when the light is glowing and see what happens (engine and ignition off).
a bad diode in the alternator can cause that. The alt will still charge, but at reduced output
Foster48x
Post by Foster48x »
You all hit the nail on the head. I pulled the exciter wire off of the alternator and the indicator light went off.
So.... is my alternator toast or about to be toast?
sounds like it's time to get the alternator rebuilt
Foster48x
Post by Foster48x »
Mark would a going bad diode show up on a bench test at a shop?
yes, it will also show up when testing on the car. There is a diode trio, as each diode fails output will be cut by a third. AND, current can flow thru the diode the opposite way as you've discovered, keeping the light on and discharging the battery
Foster48x
Post by Foster48x »
Thanks Mark. I'll look into having it repaired or replaced.
baltobernie
Hey Foster, would you satisfy my curiosity and see if you have 12V present at the (disconnected) exciter wire, with the ignition Off?
mbouse
Post by mbouse »
yeah, i thought we asked for this test earlier... but we'd surely love to hear the answer now before you have the alternator looked at by a mechanic.
Foster48x
Post by Foster48x »
New Alternator = No Battery Light when the ingnition is off. Thanks for the help.
baltobernie and mbouse, sorry I missed your posts. I purchased the new alternator this afternoon and wasn't able to test the old one.
Rick
baltobernie
All's well that ends well; Mark is usually right.
Upon reflection, I can see how a bad diode would allow voltage from the big wire to go backwards up the little wire, illuminating the charge lamp. Glad you got it fixed.
