I have a 1982 Fiat Spider 2000 that I am (after a very long down time) trying to get back on the road.
Everything is back together except the electrical hook up on the radiator fan, the sensor in the bottom of the radiator and lastly the water spray bottle connection. Seems I forgot to mark the wiring during the disassembly so I am stuck.
What makes it even stranger I can only find 2 connection and I need three. A good picture would be worth a million words.
I have the original Fiat manual but there is a lot at risk if the connections are not correct...
Thanks for any help or if you can point me in the direction to get the info I need...
Regards,
Mike P
Electrical Wiring
Re: Electrical Wiring
Mike, if you don't have them yet, Brad Artigue has put a lot of time and effort into making very good wiring diagrams available for us. You can find them here: http://www.artigue.com/cars_wiring.html.
I'm not at home this week, or I'd get pictures of the wire connections for you.
Ron
Ron
Ron, i think he needs to see the actual wires and locations of same... since they are lost in the loom.
You're right Mike, and I'd go out to the garage and get what he needs if I were home. I was suggesting Brad's diagrams in case Mike P doesn't have them yet.
Mike P; I'll be home Sunday if you don't have this solved by then.
Ron
Ron
