We have a 1980 Spider and the problem is the headlights will not go from High to Low. They go from High to off. I have seen the messages about the dim headlights and how to fix that problem, is that the same fix for this problem or is it in the high & low beam switch? It is getting close to inspection time and there is no way in this world it would pass, and I am not sure how it passed last year for the previous owner!
Hugh & Nancy Raney
Big Spring, TX
Headlights from Hell
headlights
Don't take this wrong. My wife came home and told me she lost her low beam lights. I checked and sure enough she had no low beams just high. After checking a few things I checked the bulbs and both bulbs were bad. She was probably driving with one light out for some time and didn't know it till both were bad. Fuses E & F are you low beam fuses. Under the hood drivers side there is a 2 pin connector with Gray/blk and green/blk wires feeding the headlight. Near the windshield washer bottle. You can check there if you have a troubleshooting light or voltmeter. The gray/black wire is the low beam.
