carburator problem
CrAzY RuSSian
carburator problem
Post by CrAzY RuSSian »
i got a problem with the way my engine runs. when i step on the pedal the engine sounds and feels like it is going to stall, but then the rpm's go up and everything is ok. could it be a cloged fuel filteror the pump :?: it idles fine. i am not sure what it is :?
thanks[/list][/i]
probably a worn-out accelerator pump in the carb. Easy to change; the pump housing is on the outside of the carb and retained by 4 screws
CrAzY RuSSian
:shock: can you tell me where exactly it is
thanks for your help :D
on the left side of the carb, square cover about 1" held on by 4 screws. The accelerator pump diaphragm is inside. If you remove the cover be aware of the spring that sits under the diaphragm
CrAzY RuSSian
thanks again :D
mctaco
Post by mctaco »
I may be having the same problem. Where can I find a Weber diaphram for my 75 spider? Would any auto parts store carry such a thing?
CrAzY RuSSian
i have no idea :(
mctaco
Post by mctaco »
All hope may not be lost! I just remembered that the guy I bought my car from gave me a box full of parts for the car. "I think there's a carb rebuild kit in there," he says to me. Egads! I may own the very part I need!
if not, I have them in stock separate from a kit :D
CrAzY RuSSian
mark how much would you charge for the accelerator pump or the diaphram
the pump diaphragm runs $15.50, $4.05 priority mail
CrAzY RuSSian
how do i order it :?:
I'll send you a PM
