Speedo question (1979 Spider 2000)
FinnSpider
Post by FinnSpider »
I dismantled the dash and I've got all gauges on the table. Otherwise everything looks good (except unbelievably dusty), but there is a cable at the back of the speedo which is going nowhere :shock:
If anybody has a MPH speedo in his/her hand could you be so kind to take a photo for me. Where is the yellow/red cable supposed to go?
Tappy
Your car is a: 124 spider 2000 1979
Re: Speedo question (1979 Spider 2000)
Post by Tappy »
one of the few things i took pics of, i hope they help :
http://users.telenet.be/Tappywappy/Pictures/speedo1.jpg
http://users.telenet.be/Tappywappy/Pictures/speedo2.jpg
my guess its the headlight light
FineItalianAutomobile TechnologyImage
FinnSpider
This is interesting. I have more wires ! Well, actually I don't, but my speedo does.
You see, there is a place between the speedometer rotating cable stud (is this correct?) in the middle and the 3 wires at the edge of the speedo, where 2 additional wires come from. The other is black and the other is red-yellow.
I will try to take a photo. I suppose this must be one of those "gotta see to believe" -things !
Tappy
Post by Tappy »
yes post some pics pls i also have a 79 2000 ...
TulsaSpider
Post by TulsaSpider »
You might want to make your pics a wee bit smaller Tappy.
manoa matt
Post by manoa matt »
Do you have a wiring diagram? I'd check that first.
Tappy
Post by Tappy »
TulsaSpider wrote:You might want to make your pics a wee bit smaller Tappy.
:oops: i know i didnt feel like resize and upload them again so i posted the link to them also , that way you can save them and blow them up for what they worth .... :|
mbouse
Post by mbouse »
i'm lost. are we talking cables or wires?
pope
Post by pope »
Hes talking about the red and yellow striped wire that comes from the back of the speedo and is not part of the plug. Originally that wire was solidly wired into the dash and had to be clipped to take out the dash panel. They were later twisted together upon reinstall. Check for a red /yellow striped wire that has a clipped end somewhere inside the dash. The other end of that wire is attached to a red plug
mbouse
Post by mbouse »
yellow red wire from the speedo goes to a connector where it meets yellow black wires. one yellow black wire goes to fuse panel #8 fuse. the other yellow black wire goes to the cigar lighter. this according to an old wiring diagram.
according to Brad Artigue's version the yellow red wire goes from the speedo to a connector where it meets three white red wires. those white red wires go to the clock and the tach and the optical fibre light. this occurs at the same connector mentioned above with the yellow black wires.
i dunno if this makes it better or worse for you. best i could do. if you drop me an email, i'll gladly forward BOTH wiring diagrams to you. mbouse at chartermi dot net
FinnSpider
Sorry for the delay. Here it is. Finally.
Tappy
Post by Tappy »
do you have a picture of the front also , i'm curious where that is for , looks like an extra bulp connection or so
edit: compared to my pictures it seems your missing a bulp for the dial illumination (mine is on top , on the back of the gauge) i bet there 's your extra wire ? bolt of the one screw holdong the plastic piece and see if there's a bulp underneath
pope
Post by pope »
Tappy, His speedo is correct. He just has to find the other half of the red yellow wire in the dash and twist them together.
Tappy
Post by Tappy »
i dont say its wrong just curious about the setup
pope
Post by pope »
Sorry Tappy, I thought you said he was missing something. My fault, just the way I read it.
