Hey guys:
I'm really new to fiats and I was wondering how much it would cost to get new rotors, pads, and calipers for a 2000. Thanks a lot!
Ted
Brake overhaul
it depends on where you buy the parts; Fiat vendors are usually more reasonable than the local parts store. The most exp pieces would be rear calipers, rebuilt units will run about $100 ea. Front calipers about $56 ea. Pads will vary depending on the quality, with a range from about $10 up to $50. Rotors cost in the mid $20s unless you go with slotted perf units
