ignition conversion
green75
Your car is a: 1975 124 spider
ignition conversion
Post by green75 »
Hi, I'm new to the forum so here's my first question. I would like to convert my 75 124 to an electronic ignition. possibly pertronix, I have the dual point S147H distributor. they do not make a conversion for this distro. the only appplication for the conversion is for a single point S147 distributor. could I convert the S147H distro to a single point and then put in the kit or is the housing entirely different and I would have to change to the s147. also what might be involved in converting to single point. thanks, sean
baltobernie
Re: ignition conversion
Post by baltobernie »
Here's one possibility:
http://www.advanceddistributors.com/services07.htm
Jeff rebuilt my distributor, installed a Pertronix module, calibrated, recurved and tested the finished unit for $199 including shipping. I suspect he can fit a module to your dual-point unit.
mbouse
Post by mbouse »
any special reason you wanna use the pertronix?
lots of guys grab the dist/coil/module from a carb'd '79-80 spider and have lots of success using Fiat used parts. i am willing to bet at a substantially lower cost than a new pertronix setup.
the Marelli oem units (dizzy and coil assy) sell for about $150 these days on Ebay
baltobernie
$150 used with no documentation vs. $200 from a pro? That was an easy choice for me. Plus the most important part of the rebuild; the recurve. (1) Fuel today is vastly different than 1970's gasoline (2) the OEM distributor was curved for smogged motors, not the high-performance one I'm building.
Mike, no komment on the krinkle :?: You feeling OK? :(
manoa matt
Post by manoa matt »
Bernie,
Whats the model number of that pertronix unit?
mbouse
Post by mbouse »
must be my eyesight. looks like metal flake to me. did not recognize that as krackle. sorry i disappointed you. can i see the full effect pictures?
rlux4
Post by rlux4 »
Bernie, did you have to notch the distributor cap for the pick up wires?
Ron
Ron Luxmore
rlux2n2@gmail.com
the cap has a notch that lines up with the hole in the dizzy body for the wires
baltobernie
same notch that the points wires exit
dizzy p/n S144CAY, Pertronix module MR-LS1, but I don't know if Jeff modified it to fit. It doesn't look like anything was filed off or redrilled, but I can't be certain. BTW, he recommends the blue Bosch coil or the Pertronix FlameThrower, ordinary spark plugs at 0.032" and regular plug wires.
Better pix to you later, Mike
rlux4
Post by rlux4 »
Thanks guys. I was curious and asking was easier than going out to the garage and lifting my cap to see. 8)
Ron
Ron Luxmore
rlux2n2@gmail.com
green75
Post by green75 »
thanks for all the comments. I think I'll check out the link you sent bernie. I'll let you know how it works out. Sean
green75
Post by green75 »
well due to some financial setbacks the electronic conversion is on hold. but I did convert it to single points. the directions are on international-auto.com. just remember to leave the brown wire attached to the coil or you have no tach (oops) anyhow, readjusted the timing and she runs great! can't wait for better weather to go driving. Sean
