Wiper Motor
fishboy
Your car is a: 1971 124 spyder
Wiper Motor
Post by fishboy »
Does anyone know the correct wiring order at the connector for the 5-wire version (1971)? When I purchased the car the wipers did not work. I discovered that someone had reversed two wires causing them to ground out. I now have working wipers at the full on position (both speeds) but the intermittent setting is not working. Any help?
Thanks in advance,
Bill
Bill
1971 124 sport spider 1600
2012 500 pop
mdrburchette
Re: Wiper Motor
Post by mdrburchette »
I'm showing six wires in the wiring schematic and on a wiper motor I just pulled from a 72 (should be the same as 71). The wires from the wiper motor connector should correspond with the harness connector. Here are the colors I have:
grey - goes to wiper sweep speed control switch on dash
blue/white - goes to wiper intermittent cycling switch under dash
grey/black - goes to wiper control switch at column
blue - goes to wiper sweep speed control switch on dash
black - ground
blue/black - goes to wiper control switch at column
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
