Oil Return Pipe
Oil Return Pipe
Can anyone tell me what the, "oil return pipe" is mentioned in the Haynes manual page 40? It says to make sure it is installed before refitting the oil sump (oil pan). I do not have any extra parts and I don't removing anything but I wonder if I am forgetting something. I have accounted for everything else. psg
Re: Oil Return Pipe
it's sort of an s-shaped pipe that bolts to the block inside of the oil pan
Re: Oil Return Pipe
Can you help me determine its location? Is it on all 1800's ('78). Where does it go or lead to? thks. psg
Re: Oil Return Pipe
We're not talking about the vertical tube that attaches to the side of the block that the dip stick runs through are we?
Re: Oil Return Pipe
This puzzles me as well? Is it what is commonly known as the dip stick tube?
