Fouled Spark Plugs? 1979
Re: Fouled Spark Plugs? 1979
Pescado wrote:Can you expand on “tired engine” for me
Yes. A Fiat DOHC will rev pretty high, up to 7000 rpm in stock form for the early engines, and up to 6000 rpm for the later (larger) engines. More for engines that have been built for higher rpms. However, if your engine is old and has low oil pressure, excessive wear, etc., it may not be a good idea to rev it this high. In other words, don't push an original engine that has many miles on it. That's all I meant.
Pescado
Patron 2021
Patron 2021
Your car is a: 1979 Fiat spider 124
Post by Pescado »
Gotcha….thanks Bryan
AlexD
Post by AlexD »
18Fiatsandcounting wrote:I'm kinda getting the impression that the "Italian Tune-Up" is what you need. Drive the engine hard, 4000 to 6000 rpm at full throttle for a while, and I'll bet your spark plugs will look perfectly normal. These engines love that.
Can’t say that I’ve heard the phrase “Italian tune-up” before but I love it. My Spider is coming home from the hospital soon after about 5-month of intermittent troubleshooting and repairs. Apparently she’s running better than ever (we’ll be the judge of that :-)) so the Italian tune-up should be fun regular maintenance.
