Happy to be here. I still need to post my intro, but first, I could use your help diagnosing an issue. I just bought a beautiful 1971 124 Spider last week, that has an engine and cooling from a 1979. I had it thoroughly inspected by a Fiat specialist, as well as with the eyes of the excellent forum member who sold it to me, and there were a few leaks that were addressed. However, I think some bolts came loose from its time on the flatbed, and one of them I'm having an issue with.
Had to get him out of the garage for a few minutes, and when I pulled back in, I noticed a pretty considerable amount of coolant dripping down. I took a look at the source, and one of the bolts on the bottom of the coolant outlet was loose. I put my hand down and the bolt came straight out, and then also went back in. I grabbed my sockets and wasn't able to get the bolt to catch. Not sure where the threads catch, but the inside was pretty gunked up (Loctite or some kind of waterproofing sealant?)
I've attached some pictures in an imgur album to make it easier.
https://imgur.com/a/AUwv76X
Here's a few questions that I have, that hopefully you guys can help with.
- 1) Did the tip of this bolt break off inside? Unsure of the set length of these bolts.
2) I see listings online of 1979 Coolant Outlets, but I'm unsure of what the specs are on these bolts if I just need a replacement.
3) Is there documentation for how heavy these bolts should be torqued? I was reading through the shop manual, and didn't see anything for these very specific bolts.
Thank you!!
