Timing marks - 78 cover?
architect
Your car is a: 1978 Fiat Spider
Post by architect »
Curious,
We’re there timing marks on the yellow belt cover - year 78? Any pictures?
My cover disappeared years ago.. thanks
78 Fiat 124
kilrwail
Re: Timing marks - 78 cover?
Post by kilrwail »
Yes there are three marks on the cover in a '78 model. The longest one, which is the one to use, is located about one inch above (and to the left of), the bolt that holds the cover on near the bottom. Sorry I don't have a picture to show you.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
architect
Post by architect »
Perfect! I see the marks on an eBay listing. Assuming you can adjust the timing with the cover in place, via a timing gun and reference marks?
Seems like the fan / radiator would make it hard to see?
78 Fiat 124
architect wrote:Perfect! I see the marks on an eBay listing. Assuming you can adjust the timing with the cover in place, via a timing gun and reference marks?
I think I saw the same eBay listing, but in any event, you've got your picture. Anyway, you would use a timing light and those marks as compared to the mark on the crankshaft pulley. You might need to make the mark on the pulley a little more visible with white paint or brighten it up with a small file or the like.
And yes, those timing marks are hard to see and generally not very accurate either. Generally you point the timing light in the direction of the marks and put your head down at the level of the front driver's fender and eyeball it as best you can.
maxm50
Post by maxm50 »
Let’s just say that Fiat engineers didn’t put as much thought into visibility during engine timing procedure as pininfarina did into the body styling...
1981 Fiat Spider 2000
2011 BMW 335i M-Sport
1971 Honda CB450 Twin
architect
Post by architect »
kilrwail wrote:Yes there are three marks on the cover in a '78 model. The longest one, which is the one to use, is located about one inch above (and to the left of), the bolt that holds the cover on near the bottom. Sorry I don't have a picture to show you.
Thanks!
Received the cover last night.. time to sand and paint today :)
I see the three marks as you mentioned.. can I assume the longest marker is 0 TDC? Then.. 5 and 10?
I pulled the cylinder 1 plug out today and going to try the ole whistle / stick trick to find TDC and align cams, etc.
78 Fiat 124
kilrwail
Post by kilrwail »
Yes, that's correct - zero, then 5 and 10. You should align everything for TDC with cylinder #4, not #1. Use the distributor rotor to guide you.
Peter Brownhill
architect
Post by architect »
kilrwail wrote:Yes, that's correct - zero, then 5 and 10. You should align everything for TDC with cylinder #4, not #1. Use the distributor rotor to guide you.
Ah, I see.. hopefully I’m following this correctly
#4 TDC (compression stroke).. which should align the “notch / indicator” on the crank pulley at “0” or “long marker”..
Intake and Exhaust pulleys aligned to “cam pointers”.. and Aux puppy pointing at belt tension’s bolt?
I don’t have a distributor.. using Computronix ignition.. which will require a “re-set” when everything is aligned.
Thanks Peter
78 Fiat 124
Nut124
Post by Nut124 »
Does your Computronix use vacuum advance?
How much does it advance timing with RPM?
architect
Post by architect »
No vacuum for the ignition - and timing is adjustable by twisting the unit
78 Fiat 124
Nut124
Post by Nut124 »
The Fiat, like most engines would benefit from vacuum advance for low speed torque, driveability.
What kind of an advance curve is in the unit? Is it programmable? What is you target for idle advance and top end advance?
Sorry, a lot of questions.
kilrwail
Post by kilrwail »
Thanks Peter
The auxiliary pulley should point to one o'clock.
Peter Brownhill
