Issue with water leaking
I have a 72 spider that I picked up recently. Looking over the car, found the cooling system to be low on fluid. Put water in and heard water leaking under the car. Looks like it is coming out somewhere around the intake manifold. I am trying to find an easy way to look at the issue or remove the manifold without pulling the engine. I can only seem to get to the front manifold bolts. This is a 1608 engine. Does anyone have any suggestions?
