Alternative Carb to Weber 30 DICA 1?
JohnHSpider
Your car is a: 1972 Sport Spider 850
Post by JohnHSpider »
'72 Fiat Sport Spider 850 (rear engine, 0.9L with Weber 30 DICA 1 Carb)
I've been fighting air leaks on my carb. The engine runs lean, and I've already done the overhaul where you ream out the shaft holes and replace with a larger shaft (holds the butterfly air valves). I've looked and not been able to locate the same carb available except needing to be rebuilt as I have already done on this one.
Is there an alternative carb that would bolt right up that might be more readily available?
John
bobplyler
Re: Alternative Carb to Weber 30 DICA 1?
Post by bobplyler »
I did a search on ebay, and got:
https://www.ebay.com/itm/FIAT-850-WEBER ... Swadda8H5r
I don't know anything about it.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
