Removing rear shocks
4uall
Re: Removing rear shocks
Post by 4uall »
I assume zero liability :|
moss1972
Post by moss1972 »
4uall wrote:i did it a different way :| the side that is raised lowers the opposite side, i remove the lower side then switch
think of a seesaw, /
your way would work however, possible danger with compressed spring :shock:
i did not remove the brake line either time, guess i got lucky :oops:
Once again 4uall...THANK YOU...My brake line hose was indeed feeling the axle drop. Using your pictured see-saw support method, as well as a screwdriver to leverage the lower part of the spring off the seat had the springs off in about 15 minutes. Then I could sand and repaint them with rust converter...also clean up and paint the spring seats.
Thank you all very much!!! (and 4uall too)
Steve
MA/NH
1979 Spider 2000
moss1972
Post by moss1972 »
fiat218 wrote:
4uall wrote:Thanks to all of you
Be sure to stuff a rag in the pit of despair
Thank you fiat218 and 4uall for the advice of stuffing a rag in the pit of despair!!!
Steve
MA/NH
1979 Spider 2000
