Aftermarket Fuel Injection
- Your car is a: 1982 Pininfarina Spider
Is there any reason I cant just get a system like this?
https://fitechefi.com/product/go-efi-2- ... ry-system/
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
- geospider
Re: Aftermarket Fuel Injection
I was wondering when someone would try these.
The Holly sniper as well.
Geo
Geo
- Your car is a: 79 Spider
Currently working on that install now, biggest pain in the ass is the mounting the 2GC Rochester footprint carb on a Weber footprint manifold. I've got it on using a two piece solution and a bit of filing but there are other fitment issues regarding fuel lines and carb linkages. I've yet to see how the height works out with a filter on. The head is off while I complete some other might-as-wells.geospider wrote: The Holly sniper as well.
Geo
All in all it's pretty straightforward, the unit is well thought out. I'm mounting it in a 2L block, 1800 head, single plane 1800 intake manifold, 2L FI 4/2/1 exhaust manifold with O2 sensor port. I'm using the water outlet port off an FI that I've retapped for a 3/8ths temp sensor the system requires. The other major work is running isolated power leads directly from the battery in the trunk to the Sniper under the hood, they require clean power which is pretty easy if the battery is right there, not so much in our cars. I've also replaced the original fuel tank with a fuel injection style bottom feeder, installed a new fuel pump and FI rated hoses and filters. I'm using the original hard lines as they should be adequate even though they're not the recommended size for the 400HP this unit is capable of feeding.
Anyone else thinking about this - don't buy the whole install kit. It contains a fuel return kit you won't need and a bunch of fittings that won't work in our application. You just need the Sniper, a fuel pump and filters, buy hose and fittings as needed, an AN6 banjo fitting and 9/16th bolt for the input, AN6 to 5/16th tubing to the fuel line, 9/16th to AN4 and AN4 to 1/4 barb for the return line.
Larry
- geospider
Larry,
Since you are right around the corner from me; I am in Concord and work in Oakland.
SMOG happens. What will happen with this change?
I run a 32/36 on the single plane, but switch it out to stock for 1 day out of the 2 years.
Geo
Geo
The car actually "lives" in Calaveras County, don't need to smog it unless I sell it. If my in-laws move I'm screwed...
Nope. Go for it.BammBamm wrote:Is there any reason I cant just get a system like this?
Much better than any shitty carburetor, dual or single, new or used.
Anybody wants to argue with me, I suggest trial by combat
I'll bring my dual point distributors and my SAE bolts, and we'll do a smack-down! Steiny vs. The Bryman!SteinOnkel wrote:Anybody wants to argue with me, I suggest trial by combat
Here's my reaction when my partner told me you accepted my duel.18Fiatsandcounting wrote:I'll bring my dual point distributors and my SAE bolts, and we'll do a smack-down! Steiny vs. The Bryman!SteinOnkel wrote:Anybody wants to argue with me, I suggest trial by combat
You supply the beer, and we're on! Just gotta get past this Shelter-in-Place stuff....
Meanwhile, I'll go back to twiddling with my ignition points, and my 32 DFEV. And maybe figuring out how to screw these 3/8-16 bolts into my 2L block... Maybe just needs more grease...?
Oh, and Steiny, did you replace those synchro forks to solve your slipping out of 5th gear problem... Yes?
Bryan
Bryan
Great. im so glad to hear someone else had the same idea. Im planning on taking it one step further. I got an IMI supercharger from a Mazda sedan that I am machining to mount and pipe in. I will have to turn a new SC pulley for a V belt. Do I have to have the programmable ignition for boosted application.
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
I haven't done anything to the transmission save taking it out. I got a new pilot bearing, that's it. Later this year I think I will just buy a new/rebuilt transmission and call it good. Partswise you're only a few hundred bucks short of getting a reman soooo yeah.18Fiatsandcounting wrote:You supply the beer, and we're on! Just gotta get past this Shelter-in-Place stuff....
Bryan
Absolutely. And you will need a fuel pressure regulator that's load adjusting. Not sure if the efi you are looking at has that or not.BammBamm wrote:Great. im so glad to hear someone else had the same idea. Im planning on taking it one step further. I got an IMI supercharger from a Mazda sedan that I am machining to mount and pipe in. I will have to turn a new SC pulley for a V belt. Do I have to have the programmable ignition for boosted application.
Man, I want to follow this. Go for it, this should be fun.
Not on a Fiat but still has some relevance https://www.youtube.com/watch?v=M2u7d8kajVI.
- Your car is a: 1973 spider with a 1800 swap desmoged
- Contact:
Allison has the Fitech EFI conversation set up along with adapter to mount the . Been wondering if anyone has tried this set up on there's yet. https://allisonsautomotive.com/products ... 4199889974
