What are the consequences of having the booster plunger adjusted in too far? Maybe 1/6 of an inch in ?
John
booster adjustment
- Your car is a: 1979 Spider
- AndyVAS
- Your car is a: 1980 Fiat 124 Spider
Re: booster adjustment
The pedal must travel farther before engagement.
Andy Phillips
Vick Auto - Technician, Performance Engine Builder & PFI Developer (with ITBs)
http://www.vickauto.com
Stock parts or Performance parts we've got what you need.
- Odoyle
- Your car is a: 1983 Pinafarina Spider
If the piston rod tip is extended past the specification, that would push the rear piston in the master cylinder inward farther than needed, potentially causing the brakes to lock up. You can try it, but you brakes might be glowing red after your first drive.
Thanks Odoyle,
I was driving at the piston rod receding into the booster a hair too far. About 1/16" short of the master cylinder.
Thanks again,
jb
Thanks again,
jb
