New member from Freeburg, Illinois.
- Your car is a: 1968 fiat spider
Recently purchased two 1968, 850 Spiders. Both were running when I bought them. One is an European model, with hard top. It was imported to the US last June. Presently flushing the coolant system and it will need brake work. The second one is in need of some serious wiring work. Some one installed new gauges, spliced a lot of wires and has burnt wiring. My work is cut out for me. Owned a 1972, 850 Spider back in 1974, really liked it. Will probably have lots of questions in the future.
- Your car is a: Barely Working 1972 Fiat Spider
Re: New member from Freeburg, Illinois.
I'm very excited to see pictures and the progress you make! Best of luck!
Hi! I'm from Collinsville. I only have 124's , but if you want to talk fiats I can do that. If you like to do drives the local MG & triumph clubs welcome all to join them.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
