95 amp bottom bolt
- red107
- Contact:
95 amp bottom bolt
Anybody have issues with the bottom bolt on the 95 amp alternator? I installed it and the bottom bolt is tight but its not snug. Its diameter is much smaller than the original bolt. I was thinking about a shim/collar/ to tighten it up. I remember post on a fix for this, but did a search and can't find it.
1981 Fiat Spider 2000
2018 Jeep Wrangler JLU
- Your car is a: 79 Spider
Re: 95 amp bottom bolt
I believe the instructions with the unit suggest drilling out the mounting holes and using the original bolt. I'm shelf aging mine while I finish up some other work but I plan on drilling it out when I get to it.
Larry
Larry
Used original bolt as suggested. On a side note. I've had the AR 95 amp alternator for six years now with no issues at all. I think it was one of the best mods done to the car.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
- red107
- Contact:
Thanks for the info. I will drill it out.
