Hey everyone, finally got the 1800 back together and attempted to start today, but no luck.
I am working with a 78' carb'd 1800, cranks fine, spark at plugs (wasn't before but that was due to the two wires connected to the alternator not being hooked up) but no ignition. I set the engine at TDC so cylinder 4 is at compression and then set the dizzy to spark to the #4 plug. Carb is giving her fuel, made doubly sure. So i'm slightly stumped, she cranks and cranks and cranks but no sign of firing.
Do I need the sensors underneath the intake hooked up by chance? I heard elsewhere that they are mainly for emissions and people plug them. Also considering I'm getting spark it seems like more of a timing issue that I cannot resolve. Even with spark coming out of the wires is there anything that would make the plugs spark? I connected the ground from the chassis to the trans if that is needed info. Would a weak spark create this issue, or would I at least hear it try to fire with a weak spark. Any ideas are greatly appreciated. Want to get her running soon! Thank you all.
Wont Start After Rebuild
Re: Wont Start After Rebuild
cam/crank timing?
#4 & #1 at TDC with the dots on the crank pulleys lined up the the marks on the cam housings. Aux pulley lined up tension spring bold. When the #4 and #1 cylinders are at TDC there is a notch on the crank pulley pointing towards almost the center of the aux pulley
Perhaps, if you have not already done so, have someone crank while you rotate the dist. cap.
I found quickly that on the 80 dist. the #4 pin inside the cap does not line up with the plug wire outlet.
I did a little bit, also noticed it was shocking me through the cap. so there must be a hairline crack. Even with that though with no one touching it it should still spark the plugs correct?
As Narfire says, definitely make sure that the distributor rotor points directly at the Brass pickup for the number 4 cylinder. It can be vary far away from where the number 4 looks to be on the outside of the cap.
- blazingspider
Are you sure 4 and 1 are at tdc? On my 77 when that piston pair is at tdc the notch on my crank pulley points to the long 0 degree mark on my timing belt cover.#4 & #1 at TDC with the dots on the crank pulleys lined up the the marks on the cam housings. Aux pulley lined up tension spring bold. When the #4 and #1 cylinders are at TDC there is a notch on the crank pulley pointing towards almost the center of the aux pulley
You could run a quick compression test on the cylinders. If it's good, I would suspect a distributor timing issue, if bad, I would suspect a crank to cam timing issue. When you pull the spark plugs, see if they are wet with gas. With the #1 plug out, verify TDC is where you think it should be. You can easily see the top of the piston.
Kirk
Kirk
Is the choke working properly. I cranked and cranked and cranked but even on a hot day unless you are initially choking the intake you'll never get it to fire. Do we understand you correctly that you are getting spark at the spark plugs (pull a wire and stick a screwdriver in the socket and hold it close to a ground point while a friend cranks the car and check for spark; make sure you are not holding the conducting parts!!!!). A stuck open choke caused me the same problem for a week before I figured it out!
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
1989 Spider, sold
2008 Mercedes SL65
1989 Spider, sold
2008 Mercedes SL65
Give the carb a small shot of starting fluid (have a fire extinguisher handy) and see if she tries to start. If yes, it is fuel related, if no it is ignition related. It just saves a lot of time and frustration separating which system to troubleshoot.
