I installed Vogtland lowerings prings on my '81 spider.
Ground clearance is very little now. Oil pan is about 10cm (3,9 inches) and exhaust downpipe at 9cm (3,5inches) from the ground. The oil pan I can protect with a guard, but what about the downpipe?
https://drive.google.com/file/d/1yBWdmp ... sp=sharing
lowering springs - ground clearance
- Your car is a: 1981 spider
- joelittel
Re: lowering springs - ground clearance
Wow, that is low. Did you cut the springs or is that their intended height?
Could you fabricate a downpipe guard from thick gauge sheet metal?
I didn't cut the springs, I used the Vogtland lowering springs. The car is a lower than I intended, the ride is OK though, not too harsh. But I'm worried about hitting the downpipe. Is it normal that it is lower than the oil pan? Has anywone made a downpipe guard?
picture of the car on original springs
https://drive.google.com/file/d/0Bz17so ... sp=sharing
- divace73
That may be too low.
From the front the bottom wishbones should be a close as parallel to the ground.
With those springs I predict
1. You will damage the innerside of the engine bay just on the other side of the shock tower, this will also crack the rail above the shock tower.
2. the bushes will wear out much quicker
3. You may damage the lower wishbone where the bush is housed.
4. You may hit you sump and damage it.
As a side effect you may also find the suspension is very harsh
Ask me how I know.......... 1-3 happened and 4 didn't as I had a winged sump
Cheers David
see my >>You tube channel<<
- Your car is a: 1978 Fiat Spider
Also - are these the springs you installed? I actually like the stance of your car and looking for the same without having to cut coils.
Any updates?
Any updates?
78 Fiat 124
I assume you have the rubber spring seats in place?
All spring seats are in place. Tires are 185/70R13
I drove about 2000miles this summer, it drives great. Hit the oil pan and exhaust about 2 or 3 times.
I would like to have the front 1-2cm higher so i'm thinking of installing other spring seats (where to find?) or an additional ring?
I'm not sure that something like this is available. You have to customise the spring seats or add thick washers under theses seats.Tom1B wrote:All spring seats are in place. Tires are 185/70R13
(Replacing the US heavy bumpers with EU could also help )
Fiat 124 Spider 1.8L 1978
Jaguar XKR 4.2L 2009
Harley Davidson Fat Bob 96Ci 2011
Good point, i'll try removing the bumper to see how much I gain.TwinFast wrote:
(Replacinig the US heavy bumpers with EU could also help )
The few times I hit the ground is when wife and kids were with me in the car
