Distributor Tweek
Frog2Spider
Distributor Tweek
Post by Frog2Spider »
I just finished doing some minor mods, which included a cold air intake, fuel injection mod and an exhaust header. Now I'd like to Tweek the timing, however I need to buy a wrench for the distributor hold down plate bolt.
What size is that bolt? I don't have a wrench short enough to get into the area to even size it!
Thanks!
Dave.
Frog2Spider
'81 - 2000 Spider
grrrdot
Your car is a: 1967 124
Re: Distributor Tweek
Post by grrrdot »
I believe it should be an M8x1.25 nut that uses a 13mm wrench.
-G
17mm nut, and using a crow's foot with an extension will make your life easier
Frog2Spider
Thanks Mark!
I like the 'easy' life!
Dave
Frog2Spider
'81 - 2000 Spider
