Bolt on FI Plenum
budzinsk
Your car is a: 1984 Fiat Spider
Bolt on FI Plenum
Post by budzinsk »
Hi Everyone. I was finally able to get my 84 Spider running this weekend thanks to some kind members of this forum. The engine runs well, but I heard a loud vacuum leak. It turns out I am missing a bolt on the intake plenum. I found a pic that someone else's intake plenum - see the bolt below. 3 Questions: 1. Are there any sources for this bolt , I could not find a source anywhere, new or used. 2. Does someone have a picture of this bolt on its own outside of the plenum? I can try and get a match with some of my spares. 3. What does this port do?
Rob
Re: Bolt on FI Plenum
that is an air bypass screw that is used to set idle speed. It is a special bolt with an o-ring to seal it.
KevAndAndi
Post by KevAndAndi »
In the past, I've seen this item offered by vendors, but I don't see it at this time. I'm sure someone here has an extra. It's kind of important. :)
Kevin
1981 Spider 2000
budzinsk
Post by budzinsk »
Thanks Guys... I went through the pictures I had when I got the car and started the restoration, and it looks like there was a rubber plug in there (which I still have). At least I am glad I did not lose that special bolt - it looks like I never had it..... If anyone has one, please let me know.
Rob
budzinsk
Post by budzinsk »
Midwest has this plug, but this is for the AFM and not the throttle housing. It will not work, correct?
http://midwest-bayless.com/p-11140-5924 ... e-nos.aspx
joelittel
Post by joelittel »
The plug pictured above will not work.
joelittel
Post by joelittel »
http://www.spiderroadster.com/index.htm
I've had good luck with this vendor. Send them a picture of the hole your missing idle adjustment screw should be in. That way you can be sure the two of you are talking about the same item.
Bradley Artique has a free and downloadable pdf called FIAT 124 Engine Maintenance and Modification. There my be a picture of this screw in his pdf.
something like this...
http://www.ebay.com/itm/311742278547
There's a chance that I have one, but I won't be able to check until Saturday. PM me if you need me to look.
ORFORD2004
Post by ORFORD2004 »
I think I still have the complete throttle body.
budzinsk
Post by budzinsk »
Thanks for your help guys, I really appreciate it. I will reach out to that vendor and see if they happen to have one. I will report back either way. Thanks
Rob
budzinsk
Post by budzinsk »
Thanks Everyone. Jay at Spiderroadster had one for me. It will ship out today. Thanks for the tip!
KevAndAndi
budzinsk wrote:Thanks Everyone. Jay at Spiderroadster had one for me. It will ship out today. Thanks for the tip!
Does it come with the o-ring?
Kevin
1981 Spider 2000
budzinsk
Post by budzinsk »
Yeah it did, but I will likely replace it with a new one.
