Long time lurker... First time poster......
Hey folks... glad you people are here.
I learned alot just from lurking around. I have a '76 Spider and it has a few issues, but most are getting worked out.
The biggest problem I have now is that the steering wheel has a bearing out. Can some one direct me where to find a bearing. It is the top one. otherwise life is good....you people rock...keep it up...
Schell's Beer Country
Minnesota
1976 Fiat 124 Spider 1800
Minnesota
Re: Long time lurker... First time poster......
welcome to the site! Not sure who might have a bearing, but I'll check it out on Thurs and see if they're still available
Hello, and welcome!
How long have you had your Spider? Is it stock, or modified?
And, if you've been lurking a while, you know we want to see pictures.
Ron
Ron
That makes for a question about the bearings in the steering column. I have taken off the snap ring and want to know how to remove the bearings from it.
good luck on that bearing issue. might be easier to find a whole column..
welcome to the site.
My bearing kind of fell apart when I took the shaft out.
It looks like the bearings are pressed on, so it'll take some pessure to take them off.
My steering wheel moves up and down a half inch or so....maybe i'm missing something in the turn signal assembly.
there are two machine screws and two hex head bolts that hold the steering column assembly to the bracket under the dash. perhaps some of these fasteners are loose or missing?
the picture in the parts book does not list a bearing. A bushing is listed but noted as not available. Time for a used part probably
You guys are fast....
http://i385.photobucket.com/albums/oo29 ... eering.gif Shows the exploded view.
I have a bunch of PDF's...
wiring, engine, brakes....I got them of the 'net somewhere. They looked like someone scanned them.
Thats where the pic is from... If you want I can send the PDF to you.
well, this exploda-gram lists (if you squint real careful) part #4 as BEARING
not that i've ever had mine apart to check...
in the oem Fiat book, that part is listed as a lock ring
hey hey, the microfiche shows part number 4216566 as a ball bearing and I've got 4 new ones in stock. $15 ea plus $5 for priority shipping if you're interested
- ga.spyder
Welcome to the forum.I happen to have a loose nut behind the wheel of my 82. You have GOT to tell us the story behind the ''Boss 429 Fiat''!! I have to know.
Craig
Craig
Craig Nelson
Fling It Around Turns !
