Heater will not turn off
Hi. I have a 1982 Spider that runs well but I cannot seem to stop the flow of heated air thru the vents. I live in the Florida panhandle so you should probably understand how uncomfortable it can be, even with the top down. Does anyone out there know how to turn the heat off? Is there a stuck valve or something I need to close? Thanks in advance. MJD
Re: Heater will not turn off
If you have the factory heater valve and the cable is attached and will actuate the heater valve (located on the passenger side under the dash) move the lever beside the E-brake on the drivers side forward. This should work if the hoses to and from the heater valve and core are connected correctly.
Some people in warmer climates just bypass the heater altogether.
Kirk
Kirk
- Your car is a: 1985 Spider
k9save wrote:Hi. I have a 1982 Spider that runs well but I cannot seem to stop the flow of heated air thru the vents. I live in the Florida panhandle so you should probably understand how uncomfortable it can be, even with the top down. Does anyone out there know how to turn the heat off? Is there a stuck valve or something I need to close? Thanks in advance. MJD
That happened to mine. My guess is because I only drive in warm weather and do not use the heater, the heater valve froze up. I thought I was going to have to replace it, but got it moving again.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
Thanks to all for the quick replies. Kirk, how do I bypass the heater? You are right in that I will rarely if ever use the heater.
Thanks.
Thanks.
- lglade
Here's a video on how to do it:
https://www.youtube.com/watch?v=5zSLH1mGnhI
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
2015 Subaru Outback
2017 Ford Focus RS
I don't run the heater either however foggy windows do require some warmth to clear up. I am tempted to hook the heater core back up on mine (previous owner disconnected it when they put the diesel in) although I live in the Tampa Bay area since I find myself either wiping the windows with a cotton towel and using a Harbor Freight Heated Window Defroster to keep the windshield clear on damp mornings. I put in a higher amperage lighter socket with a 15 amp fuse on it to support the electric heater however its not anywhere close to as good as the factory in dash unit.
The popular method of looping the heater hose back to itself does not work out that great in hot climates as it maintains a constant flow of coolant that bypasses the radiator and can make the engine run hotter in the summer since there is no longer a positive shut off that forces all the coolant to be pumped through the radiator when the heat control is turned to cold.
- Your car is a: 1973 Spyder 1756
Had the same problem on mine. It might be worth checking the two 'c' clamps that hold the outer part of the cable to either end. Mine were loose allowing the whole cable to move instead of just the inner control wire.
