Engine Bay Gallery! Please add your own!
aevansgatech
Re: Engine Bay Gallery! Please add your own!
Post by aevansgatech »
It's amazing what a little elbow grease can do!
1979 Spider 2000 (gone)
davery
Your car is a: 1985 Spider
Post by davery »
TX82FIAT wrote:Image
Pardon me for resurrecting an old thread, but I am getting ideas for my engine bay. Quick question, where is the AFM in the above engine bay?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
davery
Post by davery »
pgilling wrote:My engine is now bay finally finished, the overheating was caused by the Chinese knock-off fan that came with the car. I therefore bought a quality SPAL fan that solved the problem, along with a Zircotec coated exhaust manifold that kept the under bonnet temperatures down.
The link to my Spider's build progress is here: http://www.fiatspider.com/f08/viewtopic ... &sk=t&sd=a
Slight welding scar on No 1 pipe to repair a crack.
The new SPAL fan
Any ideas where the blue silicone hoses are from?
Don Avery
1985 Pininfarina
2011 Eos
joelittel
Post by joelittel »
Tx82fiat is using Vick's programmable fuel injection, which eliminates the afm.
Blue silicone hoses are from autoricambi.us i believe
Eliminating that darned AFM is an advantage in itself, any other items effected using the programmable FI?
davery
Post by davery »
joelittel wrote:Tx82fiat is using Vick's programmable fuel injection, which eliminates the afm.
I found the blue silicone vacuum, heater hoses, etc, but not the radiator hoses. I've never used silicone hoses before, can you use a straight hose and make the correct bends to work on a radiator?
Don Avery
1985 Pininfarina
2011 Eos
joelittel
Post by joelittel »
RRoller123 wrote:Eliminating that darned AFM is an advantage in itself, any other items effected using the programmable FI?
You get an entirely new wiring harness, which replaces the stock one. O2 sensor is replaced by a wide band bosch unit and the Innovate MTX-L gauge. The crank pulley is replaced by an aluminum one with a toothed trigger wheel, so you're shedding some weight there. No more thermo time switch, no more cold start injector, no more aux air valve, and the stock double relay is replaced by a new one, which is included with the new wiring harness... I'll post some pictures when I can.
Interesting. Worth a review.
ORFORD2004
Post by ORFORD2004 »
http://www.siliconeintakes.com/
pgilling
Post by pgilling »
Hello Don,
Apologies for my tardy reply. I got the hoses in the UK from Racetech hoses. Unfortunately I don't know of anywhere is the US that supplies them but I'm sure if you'll be able to find some from a race parts supplier.
Regards, PG
aevansgatech
davery wrote:
pgilling wrote: Image
Beautiful exhaust header
aevansgatech
ebrown0104
Your car is a: 1977 Spider
Post by ebrown0104 »
Last August when I bought the car:
A few weeks ago after doing an engine rebuild:
v6spider
Post by v6spider »
Engine bay update! Swapped out the plastic overflow tank and line for braided s/s and a chrome polished reservoir for the radiator.
http://www.v6spider.com
DUCeditor
Your car is a: 1977 FIAT 124 Sport Spider
Contact:
Post by DUCeditor »
What was Fiat thinking when they made the belt guard out of bright yellow plastic? That alone makes me keep my car's hood down. (Not that the rest of mine's innards are all that attractive.)
With what are you guys recoloring yours?
-don
Italian motorcycles. An Italian car. An Italian wife. What more could a man desire?
