Question about amount of oil in cam towers
joelittel
Post by joelittel »
With my engine cold how much oil should be in my cam towers? I see little puddles in all the recessed areas, but nothing more than that.
124JOE
Re: Question about amount of oil in cam towers
Post by 124JOE »
soak it up put it together and run it again then remove them again to see the same puddles
then you are fine
joelittel
Post by joelittel »
Will do.
The oil fills the small chambers until it runs over the low cast walls and runs back down through the drain holes to the sump. So relatively small puddles is the norm when you pull the covers off.
joelittel
Post by joelittel »
Thanks guys.
Does the oil (some of the oil that is) also drain down and around the valve buckets? It looks to me like a small amount would be able to seep around the edges and find it's way into the intake/exhaust chambers within the head.
124JOE
Post by 124JOE »
yes it lubes the moving parts then drains down
joelittel
Post by joelittel »
I did not fully understand how the lubrication system worked until tonight. I just watched a couple of Eric the Car Guy's videos, so now I have a much better understanding of what's going on.
Diagram is not for a 2L engine, but very similar, I think.
joelittel
Post by joelittel »
Very cool diagram. Where did you find it?
Fiat factory manual, page 10-150
joelittel
Post by joelittel »
I know what my next book purchase is going to be...
http://www.ebay.com/itm/like/3018565836 ... rmvSB=true
This is the one I took the page from. Pretty good on many things, poor on others. Need a full set to cover all the bases!
