do i want to much
LucN
Your car is a: Fiat Spider Pininfarina 1979
do i want to much
Post by LucN »
this winter i've replaced front caliper ,discs and compensator, the back calipers where replaced last year, while i tought to have a real good brake system, i still need to push the brakepedal real hard to get a descent brake distance.
do i want to much from my 79 spider or do i need to improve something else?
are you satisfied with your brake system?
Luc
baltobernie
Re: do i want to much
Post by baltobernie »
Do the brakes work better if you press the pedal several times?
vandor
Post by vandor »
I you have to push hard then likely the booster is not working. First off check that the hose from the manifold tothe booster is not kinked and has no leaks. It has to be a special hose that does not collapse under vacuum. People often use heater hose instead and after a while the hoses collapses.
LucN
Post by LucN »
Hi Baltoberni, no, this doesn' change the brake performance
Hi, Vandor, the hose is not kinked, any idea how i can test the booster?
Luc
vandor
Post by vandor »
Not sure, if you are sure it's getting vacuum and the brakes are hard to push then I'd say it's bad. Normally the brake pedal should not be at all hard to push for fast stops.
The booster has a check valve, so it sohuld have vacuum for a while after the engine is shut off. Normally one can push the pedal a few times just after the engine is shut off and the booster will still give some assist. If there is no difference in the pedal feel with the engine running or not running and the booster is getting vacuum, then the booster must be bad.
KevAndAndi
Post by KevAndAndi »
When you start the car, do you feel the brake pedal pull toward the floor a bit? If you don't feel that, it's another clue that the booster is not working.
Kevin
1981 Spider 2000
LucN
Post by LucN »
Hi KevAndAndi,
indeed, the pedal goes a bit towards the floor the moment i start the car.
Luc
DieselSpider
Post by DieselSpider »
Did you replace the rubber lines at each wheel? When they get old the central liner can start to shred and partially block the line during hard braking otherwise you may have still have a defective vacuum hose, check valve or booster.
LucN
Post by LucN »
nope, i didn't replace the lines, thx for the tip!
