Lifting the Spider
KevAndAndi
Lifting the Spider
Post by KevAndAndi »
Twister wrote:The body seems OK, but there is a fair bit of damage from ignorant lift operators who bent the jack points and the "frame rails" just south of the firewall.
The quote above is from a 2010 post.
After a little over a year of ownership, I have done a fair amount of maintenance work on our Spider, with much of it being underneath the car. I have sometimes used ramps under either the front or rear wheels and have used jack stands only under the rear axle and the front crossmember. I don't know why exactly, but I have been avoiding using the jacking points.
In the spring, I expect to take the car to a body shop to take care of some minor rust issues. I also want them to inspect the car to see if there's any problem I have missed.
I'm concerned about possible "damage from ignorant lift operators", therefore, I'd like advice on avoiding such damage. What do I need to tell the shop before they lift the Spider? Any cautionary tales?
Kevin
1981 Spider 2000
azruss
Re: Lifting the Spider
Post by azruss »
The 4 jack points are reinforced so the car can be lifted from those points without damage. If someone had trouble, it may have been due to corrosion around those points.
v6spider
Post by v6spider »
azruss wrote:The 4 jack points are reinforced so the car can be lifted from those points without damage. If someone had trouble, it may have been due to corrosion around those points.
Absolutely! I had to junk my last spider do to this kind of structural rust..
Rob
http://www.v6spider.com
v6spider
Post by v6spider »
Rob
