Center Console
davery
Your car is a: 1985 Spider
Center Console
Post by davery »
I have an 85 spider and had a few questions about the center console. My center console is OK, but has a few minor cracks and it has on crease in the vinyl on the forward section. I was looking online and was wondering how different the 79-82 consoles are from the 83-85 ones. Can I use a console from a 79-82 and still use the 83-85 upper center console? Can I use a cap and still use the 83-85 upper center console?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
Re: Center Console
the earlier console won't fit the 85 middle console without modifying it.
davery
Re: Center Console
Post by davery »
So Cal Mark wrote:the earlier console won't fit the 85 middle console without modifying it.
Thanks for the response. Could I use a 79-82 cap on an 83-85 console?
Don Avery
1985 Pininfarina
2011 Eos
Re: Center Console
the difference in the lower consoles is the area where the radio console sits, so if the cap has material in that area you'll probably have to remove it. I'm not sure the cap would keep it's shape in that case.
I have replacement fiberglass consoles for the 84-85 style
davery
Re: Center Console
Post by davery »
So Cal Mark wrote:the difference in the lower consoles is the area where the radio console sits, so if the cap has material in that area you'll probably have to remove it. I'm not sure the cap would keep it's shape in that case.
The only console I see on your website says it's for all spiders. Is that the one? If so, do you have any higher resolution pics?
Don Avery
1985 Pininfarina
2011 Eos
