new hood
kevsem65
Your car is a: 1978 fiat 124 sport spider
new hood
Post by kevsem65 »
so my wife hit a deer yesterday in my 78, dented in the hood and screwed up the dr side front fender (im freakin devastated). ive been trying to find a good hood replacement but to no avail( if anyone has a line on one pleeeaaase let me know). I can find the 79+ style hood easy , I don't really like the larger bulges but I may have to go that way. my question is, is the later style hood a direct bolt on or do other things need to be done. thx guys
1978 spider
one more time around might make it
TimpanogosSlim
Your car is a: 1977 124 Spider
Re: new hood
Post by TimpanogosSlim »
The later style hood has the later style hood prop. It's better, but you have to actually have it. You'll have to drill a couple holes to mount it. You may also need to bring the hinges along too (I forget? pins are a different diameter or something).
Getting it to line up and look perfect is another question. As i understand it, hoods were matched to bodies at the factory and no two are exactly alike.
seabeelt
Patron 2019
Patron 2019
Re: new hood
Post by seabeelt »
Definitely will need the hinges to swap with a big bump hood. Hoods are stamped so I don't know that they were custom fit to the car. Als will need the hood prop unless you can transfer the old one to the new hood. I have had both kinds of props each has its quirks and positive aspects. Your choice.
Warren
Re: new hood
Post by Warren »
If a used one will do, check with Matthews in Birmingham, AL (205)251-5800. They disassemble Fiats for parts.
Warren
Sylacauga Alabama
1979 Fiat Spider Automatic
1991 Alfa Romeo Spider Veloce
1974 Dodge Dart Sport Hang 10 (in restoration)
Multiple other cars, trucks, and boats
vandor
Re: new hood
Post by vandor »
No, hoods were not matched to the body at the factory! The Spider was a production car with about a hundred a day being built when production was at its peak.
As stated above, you need the hinges and spring that holds it up. Alternatively you can have the tab from the old hood welded to the new one and use the original prop rod.
azruss
Re: new hood
Post by azruss »
the newer the hood, the more dolphin nose it is. this can create an interference with the radiator cap if you try to fit an older hood.
kevsem65
Re: new hood
Post by kevsem65 »
After much searching I found one , funny enough from Matthews in al as the previous poster suggested!
1978 spider
