Depressurizing Fuel Injection System on an 83
Odoyle
Post by Odoyle »
Seems like there are many ways people say to do this, but I was wondering if there is a preferred method anyone would like to share. :)
Per the photo below, this looks like a decent place to try and bleed out the pressure... or am I wrong? This is on a 83 F.I. spider
ekstrandt
Patron 2019
Patron 2019
Your car is a: 1985.5 pininfarina
Re: Depressurizing Fuel Injection System on an 83
Post by ekstrandt »
Remove vacuum hose from top of fuel pressure regulator (the nut you circled is attached to it) Apply vacuum for a few seconds and you are done.
divace73
Post by divace73 »
just put a rag around the connection as it may spurt fuel
Cheers David
see my >>You tube channel<<
Turbofiat124
Your car is a: 1980 Spider 2000 turbo
Post by Turbofiat124 »
I've always pulled the fuse to the fuel pump, start the engine and let it run until it dies. Now there is no pressure.
I usually pull the hose off of the CSI, easy to get at, but make sure a rag is wrapped around it, and the engine is cold.
