What are the differences between these two tanks?
What exactly do I need to change on my Carb'd tank to use it with a FI system?
If someone has pictures of the difference or what I need to modify That would be awesome!
Thanks !
79 Carbureted Fuel Tank vs. 80 FI Fuel Tank
- srwilson
- Your car is a: 1979 124 Fiat Spider 2000
-Steve
1979 Black Fiat Spider
2006 Black Chevy Silverado Crew Cab
- bradartigue
Re: 79 Carbureted Fuel Tank vs. 80 FI Fuel Tank
The FI tank has the fuel outputs integrated into the tank. The carb tank has the fuel outputs on the (removable) sending unit. I've used both types with FI without a problem though the pump has to work a little harder because the carb output is smaller.srwilson wrote:What are the differences between these two tanks?
Thanks !
1970 124 Spider
http://www.artigue.com/fiat
- srwilson
Thanks, Brad! But I've found a new problem.
I just crawled under the back of the car and I noticed this.
After a bit of scraping the undercoating off I see I'm developing a bit of a leak.
So next question.
I do plan on switching my car over from Carb to FI at some point. I'm just not sure when I'll get around to it, but if I were to replace the tank could I use a FI tank with the Carb until I get time to switch it over?
If not, I guess i'll try and patch this small hole until I get the change over done. Will JB Weld fix the spot?
Thanks!
So next question.
Thanks!
-Steve
- 124JOE
yes jb weld it
be sure to clean it well first
- bradartigue
I personally do not mess with fuel leaks, I'd stop the leak for now with something - JB Weld as noted will work for a little while - but find an FI tank if you plan to switch. FI tanks work fine - you can even plug the fuel ports and install a carbureted Spider's fuel level sender, which has the correct size outputs for low pressure line.
1970 124 Spider
- srwilson
Thanks Brad, for the confirmation.
I'll go ahead and grab a new FI tank then.
-Steve
- aevansgatech
I developed a small tank leak as well last night I didn't notice any leak when the tank was 1/4 full, but now that it's topped off at 4/4 full I'm getting a slow drip. Either I've got a crack up high in the tank or the added fluid pressure is seeping out a small crack in the bottom.
Can JB Weld be applied to a semi full tank?
1979 Spider 2000 (gone)
- bradartigue
So long as the area is bone dry then yes. But it won't be a long term fix. I don't care what the epoxy vendors say they ALL deteriorate when exposed to fuel. Drain it, take it to a shop, have it welded.
1970 124 Spider
- aevansgatech
Yeah I agree a replacement tank or weld would be the best. I located the leak at the top of the underside part of the tank. It's at roughly ½ tank.
It wasn't in the budget but it looks like I'll have to spring for a replacement tank
